![K-Type Thermocouple With Maker UnoX And Blynk K-Type Thermocouple With Maker UnoX And Blynk](https://static.cytron.io/image/cache/tutorial/k-type-thermocouple-with-maker-uno-x-and-blynk/tutorial_First_Frame-800x320.png)
- 14 Nov 2021
- 613
In this simple video, it is demonstrated how to interface a K-Type thermocouple with Maker UnoX and display the temperature value on the 16x2 LCD and also using Blynk.
What is K-Type Thermocouple?
The thermocouple is a component that is best used for measuring temperatures that go beyond 100 °C. The bare wires bead-probe can measure air or surface temperature. The sensor consists of two dissimilar metal wires joined at one end, and connected to a thermocouple-capable device at one end.
Circuit
The connection between the components is shown in the figure below. The unconnected white colour wire connection is for the thermocouple.
As for the Grove WiFi 8266, the connection is as shown below
Grove WiFi 8266 | MAKER UNO X |
GND | GND |
VCC | 5V |
RX | 11 |
TX | 10 |
#define BLYNK_PRINT Serial
#include
#include //Click here to get the library: http://librarymanager/All#SparkFun_SerLCD
#include
#include
#include
//Software Serial on Uno, Nano...
#include
SoftwareSerial EspSerial(10, 11); // RX, TX
//Insert your Blynk project Auth Token
char auth[] = "djigt1lMWzPmqbppsEDxk6uUFNeLzf-C";
// Insert your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = "hotspot";
char pass[] = "hotspot123";
// Your ESP8266 baud rate:
#define ESP8266_BAUD 115200
ESP8266 wifi(&EspSerial);
SerLCD lcd; // Initialize the library with default I2C address 0x72
//#define DISPLAY_ADDRESS1 0x72 //This is the default address of the OpenLCD that
int thermoDO = 4;
int thermoCS = 5;
int thermoCLK = 6;
MAX6675 thermocouple(thermoCLK, thermoCS, thermoDO);
int vccPin = 7;
int gndPin = 8;
// make a cute degree symbol
uint8_t degree[8] = {140,146,146,140,128,128,128,128};
void setup() {
pinMode(vccPin, OUTPUT); digitalWrite(vccPin, HIGH);
pinMode(gndPin, OUTPUT); digitalWrite(gndPin, LOW);
Wire.begin(); //Join the bus as master
lcd.begin(Wire); //Set up the LCD for I2C communication
lcd.createChar(0, degree);
title();
delay(1000);
// Debug console
delay(10);
// Open the connection at 115200
EspSerial.begin(115200);
EspSerial.println("AT");
void loop() {
Blynk.run();
lcd.setCursor(0,0);
lcd.clear();
lcd.print("Temperature: ");
// go to line #1
lcd.setCursor(0,1);
lcd.print(thermocouple.readCelsius());
#if ARDUINO >= 100
lcd.write((byte)0);
#else
lcd.print(0, BYTE);
#endif
lcd.print("C ");
Blynk.virtualWrite(V1, thermocouple.readCelsius());
delay(1000);
void title()
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Thermocouple");
lcd.setCursor(1,1);
lcd.print("Temperature");
delay(2000);
lcd.clear();
lcd.setCursor(1,0);
lcd.print("With Maker Uno");
lcd.setCursor(3,1);
lcd.print("And Blynk");
