![WiFi Neopixel RGB LED using CircuitPython WiFi Neopixel RGB LED using CircuitPython](https://static.cytron.io/image/tutorial/wifi-neopixel-rgb-led-using-circuitpython/Cover-BI-1.jpg)
- 26 Apr 2022
- 852
I plan to add a light source to my video or live and this light can change colors. I have a NeoPixel 8x32 LED Panel, flexible type. For microcontrollers, I haven't decided yet, but it definitely supports CircuitPython.
Part 1: Design and 3D Print
This is the list of items used in the video
- Maker Pi Pico
- USB Micro B Cable
- ESP8266 ESP-01 WiFi Serial Transceiver Module
- NeoPixel 8x32 LED Panel
- Artillery Hornet 3D Printer
3D Files
You can download the STL files from Thingiverse: https://www.thingiverse.com/thing:5380104
Part 2: Wiring, IoT Platform and Coding
- adafruit_espatcontrol
- adafruit_minimqtt
- adafruit_io
- adafruit_requests.mpy
- neopixel.mpy
- CircuitPython Essentials: CircuitPython NeoPixel
- Adafruit IO Basics: Color
USB Micro B Cable
$1.00 $1.48 $1.00
ESP-01 WiFi Serial Transceiver Module (ESP8266)
$1.98 $1.98
WS2812B NeoPixel 8x32 LED Panel-256 LED
Discontinued
Maker Pi Pico: Simplifying Raspberry Pi Pico fo...
$12.00 $12.00
Artillery Hornet 3D Printer - Partially Assembled
Not Available
