Unlock a Door With Face Recognition Using ESP32 Camera
- 12 Feb 2020
- 1492
Face recognition have been used in smartphone in past few years. It is a cool technology where you can unlock your phone or to access any application that require high security. With ESP32-CAM, we can try to develop a simple application that use your face as ID. Since ESP32 board package already comes with CameraWebServer example code that cater for video stream and face recognition, let's try to modify a bit so that it can control a relay to ON and OFF.
This video shows how to unlock a door magnetic lock through face recognition using ESP32 camera.
- ESP32-CAM Wireless IoT Vision Development Board
- UC00A (FTDI) USB to UART Converter
- 1CH Active H/L 5V OptoCoupler Relay Module
- 80mm Magnetic Door Lock
- Adapter 12V 2A (UK Plug)
- DC Jack(Female) to Screw Terminal Adapter
- Jumper Wire
The custom PCB is created using CNC on Snapmaker. Below is the list of components used in the PCB.
- PCB PS 4x6inch
- Straight Female Header 1x40 Ways
- Right Angle Pin Header (Male) 1x40 Ways
- Straight Pin Header (Male) 1x40 Ways
- Mini Slide Switch(PCB)
- PCB Stand (screw & screw)10mm
Schematic and PCB files for custom PCB.
If you have Snapmaker, you can download - THIS FILES, and use it for CNC your PCB.
The program is edited directly from CameraWebServer example. Please refer to the video.
