UFO Game Using Raspberry Pi Pico 2
Step-by-Step Guide to Creating a 2-Player UFO Game Using CircuitPython
In this guide, you'll learn how to create a simple 2-player UFO game using CircuitPython on a microcontroller with an OLED display, joystick, and buttons. Player 1 uses a joystick to control their UFO, while Player 2 is controlled by the computer. The goal is to shoot the other player’s UFO.
Step 1: Set Up the Hardware
Components Needed:
  • Raspberry Pi Pico 2
  • SSD1306 OLED display
  • Analog joystick with a button
  • Wires and breadboard
Pin Connections:
  • OLED Display:
    • SCL -> GP5
    • SDA -> GP4
  • Joystick:
    • VRX (X-axis) -> GP26 (Analog input)
    • VRY (Y-axis) -> GP27 (Analog input)
    • SW (Button) -> GP22 (Digital input)
Step 2: Install Required Libraries
Ensure you have the following libraries installed in the lib folder on your CircuitPython device:
  • adafruit_ssd1306
  • adafruit_bus_device
Get the library here
Step 3: Write the Code
Download the code here
Step 4: Run the Game
  • Copy the code to your CircuitPython device.
  • Connect your microcontroller to power, and the game should start immediately.
  • Use the joystick to move Player 1's UFO and press the button to shoot. Player 2's UFO is controlled by the computer.
Video Output
