Sprinting Speed Monitor Using Raspberry Pi Pico 2
- Aishah Kamal
- 21 Aug 2024
- 64
To create a sprinting speed monitor using an ultrasonic sensor, an OLED display, and a button to stop the counting, you can follow these steps:
Components Needed:
- Ultrasonic Sensor (e.g., HC-SR04): To measure the distance of the sprinter.
- OLED Display (SSD1306): To display the calculated speed.
- Button: To stop the counting and display the final speed.
- Microcontroller: Raspberry Pi Pico 2
- Breadboard and Jumper Wires: For connections.
Concept Overview:
- The ultrasonic sensor will measure the time it takes for the sprinter to pass between two points.
- The microcontroller will calculate the speed based on the time taken and the distance between the points.
- The OLED display will show the calculated speed.
- A button will stop the counting process and display the final speed.
Steps to Implement:
Wiring:
- Ultrasonic Sensor:
- VCC to 5V (or 3.3V depending on your microcontroller)
- GND to Ground
- Trig to a digital pin (e.g., GP15 on a Raspberry Pi Pico 2)
- Echo to a digital pin (e.g., GP14 on a Raspberry Pi Pico 2)
- OLED Display:
- VCC to 3.3V or 5V
- GND to Ground
- SCL to a digital pin (e.g., GP5 for I2C)
- SDA to a digital pin (e.g., GP4 for I2C)
- OLED Display:
Get the code and library here
Explanation:
- The ultrasonic sensor measures the time it takes for the sound wave to return after being sent out, allowing you to calculate the distance.
- The speed is calculated based on the time difference between when the sprinter triggers the first measurement and when they pass the second measurement point.
- The button stops the process and shows the final speed on the OLED display.
Considerations:
- You might need to adjust the distance threshold based on your specific setup.
- Ensure the distance between the two points is accurately measured for correct speed calculation.
This project can help track and display the sprinting speed effectively using basic electronics and programming.
