![Simple Alarm System Using Maker Nano Simple Alarm System Using Maker Nano](https://static.cytron.io/image/tutorial/simple-alarm-system-using-maker-nano/CoverK-1.jpg)
Security alarms are systems designed to detect intrusion into buildings or other areas such as homes or schools. Security alarms are used for protection against theft or damage to property, as well as personal protection against intruders.
This video will show you how we make a simple alarm system using magnetic sensor on Maker Nano.
This is the sample code using Arduino IDE.
References :
Thank you
