Send Water Drink Reminder through Telegram Using micro:bit
- 20 Jul 2022
- 1538
Drinking enough amount of water every day is so important for many reasons; it can help regulate body temperature, keep joints lubricated, prevent diseases, deliver nutrients to cells, and keep organs functioning properly. Let's make a water drink reminder through Telegram using micro:bit and grove WiFi 8266.
- Follow the steps here to create Telegram bot. Get the API key of the Telegram bot and chat ID.
If you want to learn more on how to send messages to Telegram, please check the video tutorial here - After completing the code, download it on microbit
Project Complete
Upon completing the project successfully, you shall receive a message notification on your Telegram every hour.
