Robot Antenna
Robot Antenna
I have this paper robot and I want it to look fancy by adding an LED on his head. Hihi. So I decided to make this antenna and adding a sound to it using Raspberry Pi.
This is the video for this project.
HARDWARE PREPARATION
This tutorial use :
  1. Raspberry Pi 3B+
  2. Speaker
  3. Red LED
  4. 220 ohm Resistor
  5. Female to Female Jumper Wire
  6. Micro B USB
SpeakerRaspberry Pi : Audio Jack
Red LED (+)Raspberry Pi : GPIO 17
Red LED (-)Raspberry Pi: GND with Resistor
SOFTWARE
This project is using Scratch 2.0 with GPIO support.
Figure 1 : Scratch 2.0
SAMPLE CODE
Figure 4 : The Sample Code
THE IRON MAN
This is the image for the Iron Man paper craft. Kindly download it here.
REFERENCE :
  1. I took an example from this page. You can always check this page as it provides many tutorial starting from beginner to advance.
Thank you
