rero campaign in indiegogo
Rero is being launched on the indiegogo, a website for the world to raise funds from the world, and we are raising funds to create more interesting parts and production. Do check it out here and please help to support (even a t-shirt or donation for school). And most importantly, help to share it on your Facebook, tweeter, youtube, blog, WhatsApp, Viber, Chaton…… anything. We need your help and thanks in advance!
What is rero? I think you should be able to get detailed information on the rero official website. I will highlight the interesting features of rero.
The name "rero" comes from "re"-configurable "ro"bot kit. As the name says, it can be configured to any form of robot that you can imagine easily, static or with action. rero consists of a main controller and actuators, not to forget the accessories.
The rero controller
Rero controller
1st, Rero controller comes with a side slider for mounting the G15 cube servo and accessories (U joints, wheel, etc). Allow me to put the features into point form:
- PIC32MX575F512L 32-bit MCU
- Support up to 10 G15 Cube servo per port (come with 6 ports)
- Audio playback (audio files stored on a microSD card)
- 4GB microSD card
- Touch screen LCD
- Built-in Bluetooth V2.0 module (Remote control Apps for Android is under evaluation)
- USB 2.0 interface for program loading (intermediate and advanced users)
- Built-in 6 DOF IMU for balancing, orientation, and angle detection (intermediate and advanced users)
- 11.1V Lithium Polymer rechargeable battery (come with charger port on rero controller and charger)
- Able to set ID for G15, test G15, teach mode, and play mode.
A fully charged battery can last for 2 hours with four to six G15 servo motors actively being used.
G15 Cube Servo
2nd most important part of rero is G15, which is a cube servo motor acting as the actuator. Robots will require movement, G15 provides movement to robots. We are robot builders, and building robot requires parts integration. We know the long hours and pain needed to join/combine the parts, that is the reason why G15 comes into the picture. G15 is designed to offer simple integration and dismantling, without using a single screw or nut.
Two G15 connected side by side
Let's look at G15 features:
- Operating Voltage: 6.5 – 17.8VDC
- Rated Torque: 12kg.cm (at 12V)
- Speed: 63 RPM (no load at 12V)
- Gear ratio: 194:1
- Current: 1.5A max (at 12V)
- Weight: 63g
- Degree of rotation: 360 degrees continuous
- 360-degree endless electrical rotation (1088 steps)
- Communication: Half Duplex Serial
- Daisy chain connection, ready with wires and connectors
- Easy slide and lock mechanism
- 6-sided sliceable surface
OK, that is too much of a technical specification. Simple words; it is a powerful and simple-to-use actuator. We have been using it to create humanoid robots, mobile robots, robot bugs, beetle, elephant, and scorpion; simple or complex mechanisms.
Accessories
Besides the rero controller and G15, there are accessories for rero. For example, the U-joint.
U-joint on G15 Cube Servo
Foot Plate as robot foot
Wheel
Opener
We are designing the gripper and sensor module (infrared, ultrasonic, sound). That is one of the reasons we need to raise funds, to build more parts.
What can you do with rero? Build robots of course, by yourself. That is the fun of playing with robots.
Here are examples of robots:
Alien robot
Humanoid
6-legged spider?
Excavator
Scorpion
Kid with rero scorpion
Transformer?
There are plenty of robots that you can build with rero. Please visit our Facebook fan page for more photos. Again please do help to support us by backing us at indiegogo, we need every single person's support. If you have any doubt, please feel free to contact us at support@cytron.com.my
