Raspberry Pi Telegram Keypad Password
- 25 Sep 2019
- 1067
Password is a security number or phrases that need frequently updated. Continue from the previous tutorial Interface 4×4 Keypad With Raspberry Pi, this time I add extra features, one of them is you can update your password through Telegram Bot.
This video will show you about Raspberry Pi Telegram Keypad Password project.
This is the list of items
- Raspberry Pi 4 Model B
- Maker pHAT
- 2x16 LCD with I2C Module
- Right Angle Pin Header (Male) 1x40 Ways
- 80mm Magnetic Door Lock (Optional)
- 16GB Micro SD Card
- Keypad 4x4
- 1CH Relay Module
- 12VDC Solenoid Door Lock (Optional)
Wiring connection table for additional relay module.
Raspberry Pi (Maker pHAT) | Relay Module |
5V | DC+ |
GND | DC- |
MOSI | IN |
This is the sample program for Raspberry Pi Telegram Keypad Password. Please refer to the previous tutorial for LCD library setup.
- How to Display on I2C LCD Using Raspberry Pi
- Interface 4×4 Keypad With Raspberry Pi
- Displaying Telegram Message on Dot Matrix Using Raspberry Pi
