![Raspberry Pi with PIR Sensor Raspberry Pi with PIR Sensor](https://static.cytron.io/image/tutorial/raspberry-pi-pir-sensor/pir.jpg)
In this lesson, we will learn on how to use a PIR sensor module with Raspberry Pi. It’s simple and easy project to detect a motion.
HARDWARE PREPARATION
This tutorial use :
- Raspberry Pi
- Maker Hat
- USB Micro B Cable
- Low Cost PIR Sensor Module
![](https://static.cytron.io/image/tutorial/raspberry-pi-pir-sensor/RPi-3-PIR_bb.jpg)
Thank you
