PROJECT 8
ANALOG DISTANCE SENSOR TO LCD DISPLAY
Back to Project 7 | Go to Project 9 |
COMPONENT NEEDED
———————————————————————————————————————————————————-![]() | BREADBOARD |
![]() | ANALOG DISTANCE SENSOR |
![]() | ARDUINO LCD-KEYPAD SHIELD |
![]() | JUMPER WIRE |
CONNECTION
Analog distance sensor have 3 pins which is VDD, GND, Vout. Connect the Vout to analog pin-1, GND to ground and VDD to 5V.
1-Vout 2-GND 3-VDD(+5V)
ADDITIONAL INFORMATION
Referring to the chart above are the output voltage(V) versus distances(cm) of the analog distance sensor. By plotting the output voltage versus inverse number distance (1/cm), we can get the linear relation such as in figure below.
The linear equation is y = 20.99x + 0.19, where y is voltage output and x invert distance. Notice that the trusted output voltage are about 0.4 to 2.8 V.
CODE OVERVIEW
Vout = (range*500000)/1024; Get the ADC value and apply formula where to make the value in voltage with larger value. E.g: adc_value = 1022, ~ if using adc_value*5/1024, Vout = 4 ~ if using adc_value* 500000/1024 Vout = 499023 if ((Vout > 43945) && (Vout < 279785)) Check the Vout value whether is between 43945 and 279785. range = (Vout – 19000)/2099; Determine the range by apply the formula given. E.g-1 : if Vout = 279785 279785 – 19000 = 260785 1000 / 124 = 8
Set the LCD cursor and clear the value.
