STEM Robot Building Base Kit Step-by-Step Installation Guide
- 25 Jul 2023
- 759
This guide will show you on how to build your robot car base by using the STEM Robot Building Base Kit.
1. Unpack all the components and parts.
2. Mount the motor brackets (Blue) on the DC motors.
3. Secure the DC Motor with motor bracket on the plastic base, this will be the lower layer of the robot car.
Note: Make sure that the wires are facing inwardly.
4. Install the spacers on the plastic base (lower layer).
5. Secure the upper layer plastic base on the spacers.
6. Secure the steel ball castor at the bottom of the lower layer.
7. Attach the rubber wheels on the dc motors.
8. Done!
Here are some of the example connections with different type of microcontroller unit.
