Monitor Your Plants with Maker Pi Pico and A Soil Moisture Sensor
- 15 Jun 2023
- 1053
Discover how to use Maker Pi Pico and a soil moisture sensor to keep your plants happy and thriving. Get real-time insights with color-changing lights and helpful alerts. Let's get started on your plant-growing journey!
- Connect the sensor to pins GP27 & GP26
Required Libraries to Build the Code
Unzip the file, and locate these three libraries:
- neopixel.mpy
- simpleio.mpy
Copy and paste them into "lib" folder on your CIRCUITPY drive.
Most of the code has been developed by Andy Warburton, view his online page here
Project complete
To ensure accurate readings, the program begins with a calibration mode. During calibration, make sure the soil moisture sensor is completely dry to establish the maximum reading. Then, insert the sensor into a cup of water to obtain the minimum reading. After about 5 seconds of calibration, your setup will be ready. From that point forward, you can use it normally with your plants.
