micro:bit with external motor driver - MD13S
- 11 Sep 2022
- 776
If you use a micro:bit and want to control a bigger motor, you can use external motor driver with higher specification. In this tutorial, I'm using MD13S together with REKA:BIT.
- micro:bit with REKA:BIT
- 13Amp 6V-30V DC Motor Driver
- DC Brush Motor
- LiPo Rechargeable Battery
- Dean T LiPo Battery Wire Extension
This is MakeCode sample program.
- MD13S User's Manual
- micro:bit Analog Write Pin
