Measuring DC Motor RPM Through Built-in Hall Sensor Encoder
- 04 Jul 2018
- 3731
When we deal with controlling motor speed, normally we just provide PWM and the motor will rotate accordingly to the voltage reach at motor terminal. To have a better speed controlling, we can monitor RPM. Revolutions per minute (abbreviated rpm, RPM, rev/min, r/min) is the number of turns in one minute. It is a standard unit of rotational speed or the frequency of rotation around a fixed axis.
To monitor RPM, we need to have a feedback or sensor to sense shaft rotation. Luckily, nowadays, there have many DC motor in the market comes with built-in hall sensor encoder attach to the motor shaft. There have a few options offered by Cytron Technologies:
How it works? Please check on this video.
This tutorial uses:
- Maker UNO
- Cytron 10Amp DC Motor Driver
- DC Motor IG42E-24K
- Planetary Motor Bracket (IG42E/IG45)
- LiPo Rechargeable Battery 11.1V 2200mAH
- 2-3 Cell LIPO Balance Charger
You can make hardware connection based on the table below.
Connection | |
MD10C: + | Battery +ve |
MD30C: - | Battery -ve |
MD30C: A | Motor red/black wire |
MD30C: B | Motor red/black wire |
MD30C: GND | Maker UNO: GND |
MD30C: PWM | Maker UNO: pin 10 |
MD30C: DIR | Maker UNO: pin 12 |
Motor brown wire (Hall sensor VCC) | Maker UNO: 5V |
Motor green wire (Hall sensor GND) | Maker UNO: GND |
Motor blue wire (Hall sensor A) | Maker UNO: pin 3 |
Motor purple wire (Hall sensor B) | Not connected |
SAMPLE CODE
This is sample code used in the video. Enjoy it!
Thank you
