![Making A Lucky Draw Device Using Raspberry Pi Pico Making A Lucky Draw Device Using Raspberry Pi Pico](https://static.cytron.io/image/tutorial/making-a-lucky-draw-device-using-raspberry-pi-pico/Pico-Lucky-Draw.jpg)
- 27 Jan 2021
- 1087
Raspberry Pi launched the latest product called Pico last Thursday. In this regard, Cytron Technologies has made a lucky draw contest. So to decide the winner, we create a lucky draw device using Raspberry Pi Pico. How it works? Let’s watch the video.
This tutorial shows how to make a device that can generate and display the random numbers, to be used in the lucky draw contest using Raspberry Pi Pico.
- Raspberry Pi Pico
- Raspberry Pi Pico (Pre-soldered Headers)
- Maker Pi Pico
- Grove - 16 x 2 LCD (White on Blue)
- Push Button
- Buzzer
Raspberry Pi Pico GPIO Connection:
RASPBERRY PI PICO GPIO | CONNECTION |
GP12 | Button 2 |
GP13 | Button 1 |
GP14 | Grove LCD I2C (SDA) |
GP15 | Grove LCD I2C (SCL) |
GP18 | Piezo Buzzer |
RUN | Reset Button |
There are 3 files involve in this tutorial. You can refer to the video on how to put it in the MicroPython Raspberry Pi Pico.
- grove_lcd_i2c.py <--- library
- main.py
- pitches.py <--- library
