Maker Pi Pico Project Collection 2024
Microcontroller: Maker Pi Pico: Simplifying Raspberry Pi Pico for Beginners
Maker Pi Pico is a compact yet feature-packed board designed to sit at the heart of your STEM & robotics projects. Just use the jumper wires and/or Grove cables to connect any sensor and output modules to expand its capability. No soldering is required!
1. Encoder Light Blocking Sensor:
A light-blocking sensor using a Maker Pi Pico detects the presence or absence of light by measuring the change in resistance across a photoresistor.
Download the code here.
2. NFC/RFID Reader:
Read data from RFID tags with RFID reader and display on LCD. NFC is a technology that uses Radio Frequency Identification (RFID) to transmit information wirelessly over short distances.
3. Pico Invaders with OLED Display
Classic arcade game, Space Invaders, recreated on a Maker Pi Pico with an OLED display.
4. Temperature and Humidity on LCD
This project demonstrates how to use the Maker Pi Pico to read temperature and humidity data from a DHT11 sensor and display it on an LCD screen.
5. MIDI Drum with LED
A MIDI drum kit with LED lights controlled by a Raspberry Pi Pico.
6. PDM Microphone Amplitude Equalizer with Neopixel Strip
A Raspberry Pi Pico-powered microphone amplitude equalizer that visually displays audio levels with a Neopixel strip.
7. Ultrasonic Sensor triggered Neopixel Strip
Learn to use an ultrasonic sensor to trigger a Neopixel strip, creating dynamic light patterns based on distance.
8. Sound-activated Fan
Automatically turns on when it detects sound and off when it's quiet.
9. Tilt-activated Music Player (Mini box) with Neopixel Light
Tilt-activated music player box with LED lights.
10. Light Sensor with LED
Control an LED based on the ambient light level detected by a light sensor.
11. LCD Mini Arcade: Human Jumping Game
A fun and challenging arcade game where you control a pixelated human jumping over obstacles using an LCD screen.
12. Control Neopixel with a Potentiometer
Control the brightness of a Neopixel strip using a potentiometer
13. Shock sensor with Buzzer
A simple shock sensor circuit that triggers a buzzer when a shock is detected.
14. Counter with 7-Segment Display
Uses a 7-segment display to count from 0 to 9.
15. Dice with 7-Segment Display
Uses a 7-segment display to show the result of a dice roll.
37 in 1 Sensors Kit for Arduino
$16.25 $16.25
Maker Pi Pico & Kits: Simplifying Raspberry...
$9.00++ $9.00
