![Maker Nano RP2040 Interfacing With Maker Line Using Arduino IDE Maker Nano RP2040 Interfacing With Maker Line Using Arduino IDE](https://static.cytron.io/image/tutorial/maker-nano-rp2040-interfacing-with-makerline/1.jpg)
- 12 Apr 2022
- 1476
In this tutorial we shall see how to interface Maker Nano RP2040 with Maker Line. This is the continuation from the previous tutorial whereby we have seen how to control the DC motor using the Maker Drive. At the end of the tutorial we shall see how the Maker Line Following Robot function.
Since this is a continuation from the previous tutorial the additional that we will need is the Maker Line.
![2](https://static.cytron.io/image/tutorial/maker-nano-rp2040-interfacing-with-makerline/2-1024x576.jpg)
![makernanorp2040 makerdrive time 0 00 1815](https://static.cytron.io/image/tutorial/maker-nano-rp2040-interfacing-with-makerline/MakerNanoRP2040_MakerDrive-Time-0_00_1815-1024x576.jpg)
Building The Circuit
- Constructing the circuit is pretty much easy since we are using the grove connector. The connection between the devices are done as per the below figure.
![3](https://static.cytron.io/image/tutorial/maker-nano-rp2040-interfacing-with-makerline/3-1024x576.jpg)
For the code, since we have used different type of devices, please ensure that all the library has been downloaded prior to running this code.
#include "CytronMotorDriver.h"
// Maker Line Sensor Pin Connection
#define LINE_D1 6
#define LINE_D2 7
#define LINE_D3 8
#define LINE_D4 9
#define LINE_D5 10
// Configure the motor driver.
CytronMD motor1(PWM_DIR, 2, 3); // PWM 1 = Pin 2, DIR 1 = Pin 3.
CytronMD motor2(PWM_DIR, 4, 5); // PWM 2 = Pin 4, DIR 2 = Pin 5.
// The setup routine runs once when you press reset.
void setup() {
pinMode(LINE_D1, INPUT);
pinMode(LINE_D2, INPUT);
pinMode(LINE_D3, INPUT);
pinMode(LINE_D4, INPUT);
pinMode(LINE_D5, INPUT);
// The loop routine runs over and over again forever.
void loop() {
// Perform line following
int D1 = digitalRead(LINE_D1);
int D2 = digitalRead(LINE_D2);
int D3 = digitalRead(LINE_D3);
int D4 = digitalRead(LINE_D4);
int D5 = digitalRead(LINE_D5);
if (D1==0 && D2==0 && D3==1 && D4==0 && D5==0) {
motor1.setSpeed(100);
motor2.setSpeed(100); //robot move forward
else if (D1==0 && D2==1 && D3==0 && D4==0 && D5==0) {
motor1.setSpeed(50);
motor2.setSpeed(100); //move to left
else if (D1==1 && D2==0 && D3==0 && D4==0 && D5==0) {
motor1.setSpeed(0);
motor2.setSpeed(100); //robot slowing down, move more to left
else if (D1==0 && D2==0 && D3==0 && D4==1 && D5==0) {
motor2.setSpeed(50); //move to right
else if (D1==0 && D2==0 && D3==0 && D4==0 && D5==1) {
motor2.setSpeed(0); //robot slowing down, move more to right
else {
Outcome
Just remember to calibrate the maker line before start beginning the line following task.
![maker line time 0 00 5515](https://static.cytron.io/image/tutorial/maker-nano-rp2040-interfacing-with-makerline/Maker-Line-Time-0_00_5515-1024x576.gif)
