IRIV PiControl - Reading from 3 in 1 moist Sensor
- Abdulkareem Bageri
- 09 Sep 2024
- 35
By the end of this guide you will be able to get readings from 3 in 1 moist Sensor on IRIV .
- IRIV PiControl
- 24DCV power supply
- 3 in 1 moist Sensor
Connection Diagram
Note : the DC voltage used is 24V.
Programming with Node-RED
From the pllater manager install the node-red-contrin-modbus package.
Inser an inject node from the coomon platter.
Double click on the inject node and set an interval for every one second.
Insert a modbus getter node (delay node is optional) .
Set the modbus getteras following: Name = "sensor" ( optional), Unit-id = 1 (default), FC = FC 3: Read Holding Register, Address = 6, and Quantity = 3 and create a new server.
This tutorial will help you to chabge the address.
More to know:
In this step we are asking the getter node to read 3 register starting from regestier 6 (Address), the readings will be stored in a list of length 3 (Quantity).
Temperature value is in regestier 6 and it is indexed in the list as item 0.
Humidity value is in regestier 7 and it is indexed in the list as item 1.
Conductivity value is in regestier 8 and it is indexed in the list as item 2.
Set the server as following: Type = Serial, Serial port = /dev/ttyACM0, Serial type = RTU and Baud rate = 9600.
Note: in case you get no respone try changing the baud rate to 4800.
Insert three functions from the platter and name them Temeperature , Humidity and Conductivity.
Set the code of the Temperature function as follows:
Set the code of the Humidity function as follows:
Set the code of the Conductivity function as follows:
Insert a debug function for each function and make the connections.
Now you will be able to see the readings in the debug section in the right side bar.
