IoT-Based Door Lock Using micro:bit and Blynk
- 19 Dec 2022
- 1053
With this IoT-based door lock, users can have access to control the door lock remotely through their smartphones. All you need is a micro:bit, Grove WiFi 8266, and servo motor.
- Connect the servo motor to port 1
Blynk Setup
- go to Blynk website, create a new account and log in
- create a new template
- from datastream add a virtual pin
- then add a new device
- now copy the token and paste it into the micro:bit code
- on your phone, open Blynk app and click on micro:bit device
- from the widget box, add a button and select virtual pin 0
- Add “ESP8266 Cytron” extension and REKA:BIT extension as well, then follow the code block in the picture above
- Paste the Token that you have copied from Blynk, and type in "V0" in Pin section
Project Complete
Now you will have access to control the door lock remotely through your smartphone.
