How to Use OLED with micro:bit - Display Temperature and Humidity
- 23 Feb 2023
- 2732
Looking to add a little something extra to your micro:bit project? In this tutorial, we'll show you how to connect an OLED display to your micro:bit and display real-time temperature and humidity readings
- Connect the DHT11 sensor to P0
- For the OLED, connect GND to GND, 3V3 to VCC, SDA to SDA, SCL to SCK
- Add “OLED12864_I2C” extension
- Add "DHT11_DHT22" extension
- then follow the code block in the picture above
Project Complete
Turn on your REKA:BIT, the temperature and humidity reading will appear on your OLED
