MakeCode Extensions and Flashing the Code
- 30 Mar 2023
- 409
This guide is about adding the MOTION:BIT MakeCode Extension to your MakeCode Editor and flashing your code to your micro:bit.
You may get the online or offline version of the MakeCode editor as shown below:
Adding the extension into MakeCode editor
1. In your MakeCode Editor, select “Extensions” from “Category Drawer” or under the “More…” icon.
2. Search “motionbit” and select to add the extension to your MakeCode Editor.
Once you have successfully added the extension, your will be able to see the "MOTION:BIT" option at the category drawer of your MakeCode Editor
Flashing the Code
1. Connect micro USB B to your micro:bit. (Not the battery charging port on the MOTION:BIT).
2. You may choose either one of the methods to flash your code to your micro:bit:
- Method 1: Copy and paste the .hex file into the micro:bit directory.
- Method 2: Pair your computer with the micro:bit to flash (download) the code directly into the micro:bit
