![Getting Started with MOTION 2350 Pro Getting Started with MOTION 2350 Pro](https://static.cytron.io/image/tutorial/getting-started-with-motion-2350-pro/0.-motion-2350-pro-gsg-v2.png)
- 08 Aug 2024
- 692
This getting started and projects guide will help you to kick start your MOTION 2350 Pro projects with some simple guides, hardware setup or example codes including:
- Setting Up the MOTION 2350 Pro
- Power Up the MOTION 2350 Pro
- External Switch
- Blink
- Lighting Up The RGB LED
- Press the Buttons
- Turn on the Music
- DC Motor
- Micro Servo Motor
- Read Sensor Value
- Displaying Text on SSD1315 OLED module via I2C
- Flash Resetting RP2350
- USB Host & Connect to Remote Controller (COMING SOON)
MOTION 2350 Pro - Advanced Robotics Controller ...
$24.90 $24.90
