![Getting Started with Maker Feather AIoT S3 using CircuitPython Getting Started with Maker Feather AIoT S3 using CircuitPython](https://static.cytron.io/image/cache/catalog/products/MAKER-FEATHER-AIOT-S3/Get%20Started%20Guide%20Thumbnail-800x320.png)
- 22 Nov 2022
- 1077
Setting up the board
The Maker Feather AIoT S3 comes with the pre-installed UF2 bootloader. Hence you will need to program it into CircuitPython software by dragging the correct .uf2 file into the drive.
1. Click here to download the Maker Feather AIoT S3 .uf2 file or search “Maker Feather AIoT S3” in circuitpython.org/downloads.
2. To upload the CircuitPython firmware into the Maker Featehr AIoT S3, you will need to enter the UF2 Bootloader mode. Press the reset button twice.
These indicate that we’re already in the UF2 bootloader mode:
- RGB LED showing green color.
- Status LED blinking slowly.
- A drive detected as “MFAS3BOOT” in your "This PC".
Note: If you encounter any problems when you upload the .uf2 file or you cannot enter the UF2 bootloader mode, follow the instructions in the datasheet under 6.2 ROM Bootloader to reload the UF2 Bootloader in the board again and repeat Step 2.
3. Drag or copy and paste the Maker Feather AIoT S3 .uf2 file that you have downloaded previously to te drive named "MFAS3BOOT".
4. If you have successfully uploaded the CircuitPython firmware into your Maker Feather AIoT S3, you will be able to see a CIRCUITPY drive on your computer.
5. Before you start to code, make sure that the “CircuitPython (generic)” has been chosen as the interpreter (if applicable) in your coding software. And the required lib bundle can be found here.
We have prepared some simple example codes that you may start with:
- Example 1: Blink
- Example 2: Lighting Up The Neopixel RGB LED
- Example 3: Turn on the Music
- Example 4: Read Analog Sensor Value
- Example 5: Entering Sleep Mode on Maker Ports
- Example 6: Displaying Text on SSD1315 OLED module via I2C
- Example 7: NTP Clock
Example 1: Blink
#import necessary libraries
import board
import digitalio
import time
#initialize leds on D14, D21 and D47 pins
led1 = digitalio.DigitalInOut(board.D14)
led2 = digitalio.DigitalInOut(board.D21)
led3 = digitalio.DigitalInOut(board.D47)
#set the led pins as output
led1.direction = digitalio.Direction.OUTPUT
led2.direction = digitalio.Direction.OUTPUT
led3.direction = digitalio.Direction.OUTPUT
while True:
#led1 is light up for 0.5s then turned off
led1.value = True
time.sleep(0.5)
led1.value = False
time.sleep(0.5)
#led2 is light up for 0.5s then turned off
led2.value = True
time.sleep(0.5)
led2.value = False
time.sleep(0.5)
#led3 is light up for 0.5s then turned off
led3.value = True
time.sleep(0.5)
led3.value = False
time.sleep(0.5)
3. Flash the codes to your Maker feather AIoT S3. And your CIRCUITPY drive should look like this (no lib file is used):
4. You may also try to flash this code to your Maker Feather AIoT S3 and observe what will happen to your Maker Feather AIoT S3.
import board
import digitalio
import time
#define all of the led pins on the board in an array
led_pins = [board.D14,
board.D15,
board.D16,
board.D21,
board.D47,
board.D48,
board.D38,
board.D39,
board.D40,
board.D41,
board.D42]
#set all of the led pins as output
led = []
for pin in led_pins:
# Set pins as digital output
digout = digitalio.DigitalInOut(pin)
digout.direction = digitalio.Direction.OUTPUT
led.append(digout)
while True:
#Turn on LEDs one-by-one very quickly
for i in range(len(led)):
led[i].value = True
time.sleep(0.15)
# Turn off LEDs one-by-one very quickly
led[i].value = False
time.sleep(0.15)
Example 2: Lighting up the Neopixel RGB LED
import board
import neopixel
import time
# Initialize Neopixel RGB LED on pin D46
pixels = neopixel.NeoPixel(board.NEOPIXEL, 46)
#Clear Neopixel RGB LED
pixels.fill(0)
#Set pixel brightness
pixels.brightness = 0.5
while True:
#Light up Neopixel RGB LED with purple colour
#the sequence of the colour code is (R,G,B) input range is from 0-255 (decimal)
pixels.fill((200, 0, 200))
time.sleep(0.5)
pixels.fill(0)
time.sleep(0.5)
3. Flash the codes to your Maker feather AIoT S3. And your CIRCUITPY drive should look like this:
Library file(s) required:
neopixel.mpy
#Import necessary libraries
import board
import neopixel
import time
pixel = neopixel.NeoPixel(board.NEOPIXEL, 46)
pixel.fill(0)
pixel.brightness = 0.5
#Define each colour codes in RGB decimal format
RED = (255, 0, 0)
ORANGE = (255,180,0)
YELLOW = (80, 80, 0)
GREEN = (0, 255, 0)
CYAN = (0, 255, 255)
BLUE = (0, 0, 255)
PURPLE = (180, 0, 255)
WHITE = (100, 100, 100)
#Group all the colours in an array
colour = [RED,ORANGE,YELLOW,GREEN,CYAN,BLUE,PURPLE,WHITE]
while True:
#Light up the neopixel RGB LED and change the colour every 0.15s
for i in range(len(colour)):
pixel.fill(colour[i])
time.sleep(0.5)
import board
import digitalio
import simpleio
import time
#Define the Melody Note and Duration
MELODY_NOTE = [659, 659, 0, 659, 0, 523, 659, 0, 784]
MELODY_DURATION = [0.15, 0.15, 0.15, 0.15, 0.15, 0.15, 0.15, 0.15, 0.2]
#Define pin connected to piezo buzzer
PIEZO_PIN = board.D12
#Initialize buttons
btn1 = digitalio.DigitalInOut(board.D3)
btn1.direction = digitalio.Direction.INPUT
btn1.pull = digitalio.Pull.UP
#Play melody during start up
for i in range(len(MELODY_DURATION)):
#The boad will not work with 0 frequency, so everytime the frequency is 0, it will rest for a duration of time
if MELODY_NOTE[i] == 0:
time.sleep(MELODY_DURATION[i])
else:
# Play melody tones
simpleio.tone(PIEZO_PIN, MELODY_NOTE[i], duration=MELODY_DURATION[i])
while True:
# Check button (D3)
if not btn1.value: #Button is pressed
# Play tones
#Format(pin,frequency,duration)
simpleio.tone(PIEZO_PIN, 262, duration=0.1)
simpleio.tone(PIEZO_PIN, 659, duration=0.15)
simpleio.tone(PIEZO_PIN, 784, duration=0.2)
simpleio.mpy
2. Connect your sensor module to one of the maker ports using stemma QT to 4 female pins / grove cable.
import board
import time
import analogio
#Define analog pin A3 used on the board
sensor = analogio.AnalogIn(board.A3)
while True:
#Serial print the sensor value every 1 second
print(str(sensor.value))
time.sleep(1)
4. Flash the codes to your Maker feather AIoT S3. And your CIRCUITPY drive should look like this (no lib file is used):
Example 5: Enter Sleep Mode on Maker Ports
Note: GPIO LED, RGB LED, Piezo Buzzer and Maker Port (H) are powered by the Vperipheral. Make sure it’s enabled by turning on D11 before using them.
2. Connect your sensor module to one of the horizontal maker ports using stemma QT to 4 female pins / grove cable.
import board
import time
import analogio
import digitalio
#Define digital pin D11 used on the board as the switch
# D11 pin is used to turn on/off the Vperipheral, which powers the GPIO & RGB LEDs, piezo buzzer and Maker Ports (horizontal).
# You can check the status of D11 pin by observing the LED next to VP pin.
vp_switch = digitalio.DigitalInOut(board.D11)
vp_switch.direction = digitalio.Direction.OUTPUT
while True:
#Turn on led switch on D11
vp_switch.value = True
#Serial print analog sensor value
time.sleep(2)
#Turn off led switch, then sleep for 10 seconds
vp_switch.value = False
time.sleep(10)
Example 6: Displaying text on SSD1315 OLED module via I2C
2. Connect your OLED module to the maker port marked "CL" and "CA" using stemma QT to 4 female pins / grove cable.
import board
import busio
import adafruit_ssd1306
# Define the i2c GPIOs on D41 and D42
#format: (board.SCL, board.SCA)
i2c = busio.I2C(board.D41, board.D42)
# Define the OLED display using the above pins
#format: (width, length, i2c pins)
oled = adafruit_ssd1306.SSD1306_I2C(128, 64, i2c)
while True:
# Clear the OLED display
oled.fill(0)
# Write the data: ('text', x , y, pixel colour)
# Pixel colour: 0 = false, 1 = true
oled.text('Hello world!', 0, 0, 1)
oled.text('Yeah!', 0, 25, 1)
# Show the written data
oled.show()
4. Flash the codes to your Maker feather AIoT S3. And your CIRCUITPY drive should look like this:
File(s) required:
font5x8.bin
import time
import socketpool
import wifi
import adafruit_ntp
# Get wifi details and more from a secrets.py file
try:
from secrets import secrets
except ImportError:
print("WiFi secrets are kept in secrets.py, please add them there!")
raise
#Connect to wifi
print("Connecting to WiFi")
wifi.radio.connect(secrets["ssid"], secrets["password"])
print("Connected!")
#Setting up the wifi conenction into the socketpool
pool = socketpool.SocketPool(wifi.radio)
#Defining ntp function with GMT +8 timezone
ntp = adafruit_ntp.NTP(pool, tz_offset=8)
while True:
#Print ntp time (year, month, date, hour, min, second) every 1 second
print(ntp.datetime)
time.sleep(1)
3. Create another file and name it as secrets.py, then copy the following code to your editor:
#Change it to your wifi SSID and Password
secrets ={
'ssid':'Your wifi SSID',
'password':'Your wifi Password'}
adafruit_ntp.mpy
Maker Feather AIoT S3: Simplifying AIoT with ESP32
$19.95++ $19.95
