![Turn on the Music Turn on the Music](https://static.cytron.io/image/tutorial/get-started-motion-2350-pro-circuitpython-turn-on-/7.-turn-on-the-music-v2.png)
Turn on the Music
- 08 Aug 2024
- 150
This guide will show you how to program the buzzer on your MOTION 2350 Pro to play some melody.
The figure below shows the GPIO for the on-board Piezo Buzzer.
2. We will let the MOTION 2350 Pro make some sound during start up and when the button on the board is pressed. So, copy and paste the following code to your editor.
3. Flash the codes to your MOTION 2350 Pro and try to press the button. Your CIRCUITPY drive should look like this:
Library file(s) required:
simpleio.mpy
MOTION 2350 Pro - Advanced Robotics Controller ...
$24.90 $24.90
