![Blink Blink](https://static.cytron.io/image/tutorial/get-started-motion-2350-pro-circuitpython-blink/4.-blink-v2.png)
Blink
- 08 Aug 2024
- 220
This guide will show you how to light up the LEDs on your MOTION 2350 Pro.
The figure below shows the GPIO for each of the on-board status LED.
3. Flash the codes to your MOTION 2350 Pro. And your CIRCUITPY drive should look like this (no lib file is used):
MOTION 2350 Pro - Advanced Robotics Controller ...
$24.90 $24.90
