![Lighting Up the RGB LED Lighting Up the RGB LED](https://static.cytron.io/image/tutorial/get-started-motion-2350-pro-circuitpyhton-lighting/5.-lighting-up-rgb-led-v2.png)
- 08 Aug 2024
- 194
This guide will show you how to light up the RGB LED on your MOTION 2350 Pro.
The figure below shows the GPIO for each of the on-board status RGB LEDs.
3. Flash the codes to your MOTION 2350 Pro. And your CIRCUITPY drive should look like this:
Library file(s) required:
neopixel.mpy
MOTION 2350 Pro - Advanced Robotics Controller ...
$24.90 $24.90
