DIY Piano Paper With Raspberry Pi Pico
- 22 Jul 2023
- 869
Ever wondered if a piece of paper can turn into a touch-sensitive piano? In this exciting DIY tutorial, we'll show you exactly how to transform a simple sheet of paper into a fully functional touch-sensitive piano using the Raspberry Pi Pico!
Unzip the file, and locate this library.
- neopixel.mpy
- simpleio.mpy
Copy and paste them into "lib" folder on your CIRCUITPY drive.
Project complete
Take a sheet of paper and draw a piano keyboard using a pencil. Stick jumper wires on the keys using tape or blu tack. Your magical Piano Paper is all set!
