DIY Interactive Robot using REKA:BIT with micro:bit | Tutorial for Beginners
This awesome robot involves using servo motors, DC motors, LEDs, and a potentiometer. Other than that, the robot will help you to be familiar with most of the MicroBit sensors such as sound sensor, light sensor, and temperature sensors.
Video Tutorail
Step 1: Components and Tools
1tools
2tools
Tools Required:
Step 2: Use Cardboard to Make the Robot Body
Cut the cardboard to the dimensions shown in figure 1
Interactive Robot - A4 Template.pdf
1
Use the glue gun to attach the right side
2
Use the glue gun to attach the left side
3
Attach the breadboard holder as shown in figure 4
4
Make sure to leave a little space for the ease of wire connection
5
Step 3: Connection
compressjpginteractive robot circuit diagram
  • The first grove port of REKA:BIT will be connected to the potentiometer
  • Connect LEDs to the breadboard, where: The long leg (Anode) should be connected to the output pin. The short leg (Cathode) should be connected to a resistor, and the resistor will be connected to the ground pin. After that, connect the female wires coming from the grove port to the male wires on the breadboard
  • Connect both servo motors to the servo ports number 1 and 2
  • Connect the DC motors to their terminals
Step 4: Attach Components to Cardboard
Insert the potentiometer in the middle
slide1
Place the breadboard over the cardboard piece
slide2
Attach servo motors
slide3
Place DC motors on the bottom sides
slide4
Attach REKA:BIT and fix it using cable ties
slide5
Insert the caster wheel into a piece of cardboard and place it at the bottom
slide6
Place the battery holder over the cardboard piece
slide7
Make the circuit connection as shown in the previous step
slide8
Attach the ice cream sticks to servo motors
slide9
Close the top side with a cardboard pieceslide10
Step 5: Code
code
Now, connect the MicroBit to your device and open MakeCode editor to start programming.
  • Add REKA:BIT extension and follow the code block in the picture above
  • After completing the code block, download it and compile it over REKA:BIT
Well Done!
interacticerobot (1)
Awesome! the interactive robot is ready to go.
Turn on REKA:BIT and enjoy having fun with it.
Don't forget to show your cool robot to your friends!
SG90 Micro Servo -17% Best Seller
SG90 Micro Servo
$1.63 $1.95 $1.63
