DIY Football Game Using REKA:BIT With Micro:bit
- 27 Aug 2021
- 746
Let’s learn how to make a "Penalty Kick Game" using REKA-BIT with micro:bit! It's fun, easy to make, and you can play it with your friends! ⚽️✨
Step 1: Components and Tools
- 1x Servo Motor
- 1x Ultrasonic Sensor
- 1x Grove to female header cable
- 1x Powerbank
Tools Required:
- Cardboard
- Ice Cream Stick
- Hot Glue Gun
- Glue Stick
- Scissor
- Cable Ties
All listed components can be found on our website Cytron Technologies !
Step 2: Use Cardboard To Make The Game
Here we have cardboards and also we have a template in A4 size (I've attached this template below, print it out) | |
Cut the cardboard based on the template you have | |
You will notice every part is has been numbered, attach number 1 & 2 with part number 3 | |
Attach number 4, 6 & 7 on the top side | |
Attach number 5 on the top side as well | |
Bring ice cream sticks and place them on the two thin black line on part 4 | |
Take another ice cream stick and reduce its length to seven centimeters and then attach it with the servo motor | |
Ultrasonic sensor will be placed on the left side of part number 6 | |
Part number 8 will be attached on the backside, REKA:BIT will be attached on part 8 using cable ties. | |
To make the ball, take a sheet of paper then start scrunching the paper, then bring some water and let the paper get wet, and then keep rolling until you have a nice circular ball |
Step 3: Connection
- Connect the servo motor to the S1 port
- Connect the ultrasonic sensor to the first Grove port
- Power up the REKA:BIT using power bank
Step 4: Code
Well Done!
You've made it, the game is ready!
Turn on REKA:BIT and enjoy playing the amazing game you just built
Don't forget to bring your friends over and challenge them
