![DIY Digital Alarm Clock Using REKA:BIT With Micro:bit | Tutorial for Beginners DIY Digital Alarm Clock Using REKA:BIT With Micro:bit | Tutorial for Beginners](https://static.cytron.io/image/cache/tutorial/diy-digital-alarm-clock-using-rekabit-with-microbit-tutorial-for-beginners/Thumbnail-800x320.png)
- 22 Oct 2021
- 725
LCDs are very popular and useful when you need to display some information like sensors data from your project, and once it comes to use it with REKA:BIT it couldn't be easier. So let’s build a digital alarm with LCD and potentiometers.
Step 1: Components and Tools
- 1x 3V3 I2C 1602 Serial Character LCD
- 2x Potential Meter 10K
- 3x Grove to female cable
- 1x Battery Holder
- 4x Cable ties
- 1x Box
Step 2: Make Alarm Box
Grab the box and make holes in it as shown in the figures below:
Step 3: Attach Components to the Box
By following the figures below:
- Fix REKA:BIT and LCD in the box using cable ties
- The potentiometer should be inserted above the LCD
Step 4: Connection
- Connect both of the potentiometers to the 1st and 3rd ports.
- Connect the LCD to the 6th port
Step 5: Code
⚠️ Please check out this tutorial for a clearer understanding of how to use the 3.3V LCD with micro:bit.
Project Completed!
Turn on REKA:BIT and start by adjusting the current time, after that proceed to set the alarm
- Hold A button and rotate the potentiometer to adjust the time
- Hold B button and rotate the potentiometer to set the alarm
Potential Meter 10K
$0.30 $0.30
3V3 I2C and SPI 1602 Serial Character LCD
$4.63 $4.63
$35.50 $39.25 $35.50
