Displaying Temperature and Humidity on OLED Using Maker Pi Pico
- 29 May 2023
- 1970
Learn how to display temperature and humidity on an OLED screen using Maker Pi Pico! In this tutorial, we'll guide you step-by-step through the setup and coding process. But that's not all! By the end of this tutorial, you'll have the knowledge and skills to tackle other cool projects using OLED display. Let’s get started!
- Connect the DHT11 sensor to GP27 and leave the white wire unconnected
- For the OLED connect SDA to GP0 and SCL to GP1
Required Libraries to Build the Code
Before we dive into the tutorial, we need to make sure we have the necessary libraries installed to use the OLED and DHT sensor.
Unzip the file, and locate these three libraries:
- adafruit_dht.mpy
- adafruit_framebuf.mpy
- adafruit_ssd1306.mpy
Copy and paste them into "lib" folder on your CIRCUITPY drive.
Also, you will need (font5x8.bin) file to be added to your CIRCUITPY drive, so you can use the OLED.
Project complete
By completing this project, you will have a functional system that can measure temperature and humidity using a DHT11 sensor and display the readings on an OLED screen. This can be useful in various applications such as weather monitoring, environmental sensing, or home automation projects where temperature and humidity data are important.
