How to Display on I2C OLED Using Raspberry Pi
- 25 Jul 2018
- 1173
Not all Raspberry Pi project will involve monitor to display, because it is big. If there have an option with smaller display, why don’t you try it? It is helpful to display a simple status, sensor data reading, even to display your name. So in this tutorial, I will share with you on how to display on I2C OLED using Raspberry Pi.
This video will show you how to display on I2C OLED using Raspberry Pi 3 Model B+ (2018-06-27-raspbian-stretch).
HARDWARE CONNECTION
You can directly connect I2C OLED to Raspberry Pi or using additional HAT.
- Raspberry Pi 3 Model B+
- 5V 3A Adapter
- OLED I2C 0.96Inch 128x64
- Raspberry Pi Zero WH
- 16GB Micro SD Card
Thank you
Credit to:
- Adafruit for OLED library.
- www.raspberrypi-spy.co.uk for tutorial.
