Control Servo With Gesture Using ESP32 and Arduino
- 13 Nov 2019
- 1397
Do you interested in gesture? There have sensor that able to sense gesture which is PAJ7620U2. This sensor can recognize 9 gestures and the gesture information can simply access via the I2C bus. The 9 gestures are:
- Move Up
- Move Down
- Move Right
- Move Left
- Move Forward
- Move Backward
- Circle-Clockwise
- Circle-Counter Clockwise
- Wave
Since the max supply voltage and I/O are ~3.3V, so I decided to interface with ESP32 board. To make it more interesting, I use servo as an output actuator.
This video will show you how to control servo movement using gesture using ESP32 and Arduino.
- Node32 Lite Wifi & Bluetooth Development Kit
- PAJ7620U2 9 Gesture Recognition Sensor Module
- Analog Micro Servo 9g (3V-6V)
- Breadboard 16.5x5.5cm (830 Holes)
- Male to Male Jumper Wire
This is Arduino sample sketch to sense gesture and control servo movement. Please install 2 additional library at Arduino IDE Library Manager:
- Gesture PAJ7620 by Seeed Studio Version 1.0.0
- ESP32Servo by John K. Benneth, Kevin Harrington Version 0.6.0
- Hand Gesture Recognition Sensor (PAJ7620)
- Tech Note 104 - Adding Gesture Control to your Arduino / ESP projects
