![Control PikaBot Using a Phone Through Bluetooth Control PikaBot Using a Phone Through Bluetooth](https://static.cytron.io/image/tutorial/control-pikabot-using-a-phone-through-bluetooth/Cover.jpg)
Have you tried to program PikaBot:
✅ Simple Movement
✅ Follow the line
✅ Avoid Obstacles
If you have done that, you can now challenge yourself to control PikaBot using a phone.????
Watch this video for more info on how to Control Pikabot using a phone through bluetooth.
This is the sample code used for this project.
Thank you
Thank you for reading this tutorial and we hope it helps your project development. If you have any technical inquiries, please post at Cytron Technical Forum.
