Control ESP32 Mobile Robot Using Android Bluetooth App
- 09 Oct 2019
- 1967
Besides the WiFi module, ESP32 also equipped with Bluetooth modules. So in this tutorial, I will share with you how to use the Bluetooth module and control ESP32 mobile robot using an Android app. Before that, you may need to refer the following tutorial first:
- Data Logging Using Favoriot IoT Platform and ESP32 (to install ESP32 board package)
- ESP32 PD Line Following Robot with Maker Line (for wiring connection)
This video will show you how to control the ESP32 mobile robot by using the Android Bluetooth app.
- Node32 Lite
- 2WD Smart Robot Car Chassis
- Breadboard 8.5x5.5cm
- Maker Drive
- LIPO Battery 7.4V 900mAH
- 40 Ways Male to Female Jumper Wire
Wiring connection table
7.4V LIPO BATTERY | MAKER DRIVE | DC MOTOR | NODE32 LITE |
Positive | VB+ | ||
Negative | VB- | ||
M1A Terminal | Left Motor | ||
M1B Terminal | Left Motor | ||
M2A Terminal | Right Motor | ||
M2B Terminal | Right Motor | ||
5V | RAW | ||
GND | GND | ||
M1A Pin | GPIO33 | ||
M1B Pin | GPIO25 | ||
M2A Pin | GPIO26 | ||
M2B Pin | GPIO27 |
This is the Arduino sample for ESP32. Please install the ESP32 board package manager in order to compile and upload the code successfully.
- ESP32 Pinout References
- Maker Drive Datasheet
