Bluetooth HC-05 master-slave configuration using CircuitPython
- 31 May 2022
- 1636
To allow 2x Bluetooth modules to communicate with each other, we need to set the module to master and slave modes. In this tutorial I will show how to do the setup using CircuitPython.
This is CircuitPython sample program. It has been tested using CircuitPython 7.3.0.
- How To Configure and Pair Two HC-05 Bluetooth Modules as Master and Slave
- CircuitPython Documentation: busio UART
