Basic Usage of iMAX B6AC LiPo Charger
- 30 Oct 2019
- 1386
Do you have a bad experience with LiPo battery? Normally everything is ok when you bought it. After a few usages, you plan to keep it for a certain period. Then, the problem starts (if you're an unlucky guy). Either it becomes puffy or the battery is flat. In this tutorial, I will share the basic usage of iMAX B6AC so that (hopefully) it can avoid those problems.
This video will share on how to use iMAX B6AC to charge LiPo and also the storage mode if you plan to keep your LiPo in a long time.
- SKYRC IMAX B6 Multifunction Charger: Overview and Basic Usage
- iMAX B6AC Instruction Manual (included in the charger box)
