![Automatic Plant Watering System Using REKA:BIT Automatic Plant Watering System Using REKA:BIT](https://static.cytron.io/image/tutorial/automatic-plant-watering-system-using-rekabit/Rekabit-Automatic-Plant-Watering.jpg)
- 22 Jul 2021
- 2985
Let's learn and build a simple automatic watering plant system using REKA:BIT. ? Press button A to get the sensor reading.
- REKA:BIT - Simplifying Robotics with micro:bit
- Grove - Capacitive Soil Moisture Sensor (Corrosion Resistant)
- Micro Submersible Water Pump DC 3V-5V
This sample program is using MakeCode. Before that you need to add the extension of "rekabit".
![makecode automaticplantwatering](https://static.cytron.io/image/tutorial/automatic-plant-watering-system-using-rekabit/MakeCode-AutomaticPlantWatering-1024x576.jpg)
$0.98 $0.98
Grove - Capacitive Soil Moisture Sensor (Corros...
Discontinued
$35.50 $39.25 $35.50
